Adding a Shore Power Utility Plug-gctid524127
    So my little project begins. My boat does not have ANY Shore Power at this time, and as I leave it in the water I wanted a safer way of getting power into the boat for tools, charger, heater or whatever.
    Thanks to SomeSailer at APlus Mobile Graphics & Design for making the custom panel.
    The design was inspired by EZacdc Boat Wiring products, but I needed something less elaborate and less expensive.
    I rounded the prices up to the next dollar for simplicity.
    $20.00 Custom Panel
    $15.00 20 AMP Breaker
    $ 8.00 15 Amp GCFI outlet
    $ 7.00 15ft green wire for safety/bonding run
    $10.00 8ft 12/3 flat boat wire
    $ 3.00 Red LED
    $ 3.00 Green LED
    $70.00 Shore Power Inlet (not pictured)** Price is approximate
    **I actually found a shore power inlet at Pacific Marine Exchange for $30.00 but there are several models available in the $30-$80+ range depending on material and your needs.
    Now Budgeting $136 for a utility outlet may seem like a bit much and you may be wondering if DIY is really saving anything.
    Well, you be the judge.
    [ul]
    [li]A BlueSea panel that JUST has the Breaker and LED's, no outlet, nothing else, just a panel with a breaker and two LED's is about $100.00..[/li]
    [li]The EZacdc Shore Power solution, while it does have a box and an outlet and comes with the inlet with a pre-wired harness starts at $285.00[/li]
    [/ul]
    Here are the parts not including the shore power inlet I left on the boat, and some screws.
    [img size=600]http://farm6.staticflickr.com/5542/11373889366_3262ce758d.jpg[/img]
    Aquatic Muse
    Mount Vernon, WA
    MMSI: 367498870
    '79 Bayliner Santiago w/ Mercruiser 470 power and drive
