3288 Engine louvres-gctid512159
    My 3288 engine louvres have suffered quite badly and I spent quite a time working out how best to restore them. Eventually I settled on replacements made from stock aluminium tube and King Starboard. So if there is more damage they can quite easily be re-built. I have attached a few pics to show the general idea
    very nice - just curious what the dims are for the rectangular tubing, and how you finished the ends??
    ________________
    1989 Bayliner 3270
    135hp (stock) -> 150hp (Injector pump mod) -> 170 hp (aftercoolers) Hino's
    MMSI 316 021 107
    Past Commander, Seymour Power and Sail Squadron
    Current instructor North Shore Power and Sail Squadron
    Vice Commodore BYC
      The ali tube is 15mm square anodised. I thought this was sufficient protection for salt water but we shall see. You are right to pick up on the ends though - these were a bit of a headache! Obviously raw ali is exposed when you cut the tube at the required 45 degree angle. I thought about making plastic plugs but in the end I settled on a piece of anodised flat ali spanning each end (across all 4 tube ends) which I clear silconed on making sure the silicon covered all cut surfaces. So far no corrosion problems!
        Nice! My 3270 look cheap but are in good shape I would like to remake them anyway,
          Great Idea..... thank you for sharing!
