Leaking 192 discovery-gctid357479
    Hi all ,need some advice on my 192.purchaced new last november,1st time out noticed bilge pump turn on 4 times,had a look inside engine compartment & noticed some water comming from the bolts that go through the transom holding the full lenght swim platform.returned boat ,they removed bolts & put some marine sealant in .i returned the boat to the water & had the bilge turn on 4 times again(but no water comming from the bolts.returned boat to dealer and they found a hose not fitted from the factory(on the port side close to the water line their is 2 white skin fitting they are for the lid drains for the storage compartments in the floor.the front compartment hose was not fitted).returned boat to the water but i still have the same problem,returned boat today to the dealer .any advise welcome thanks tass
    Any hole in the hull can leak... A new boat should not leak one drop.
    There is no way someone who can't touch your boat can give advice where the water is coming in from.
      I agree completely, a new boat should not leak and its the dealers responsibility to sort it.
      All you can really do is get the bilge completely dry and then go out on the water, preferably on a calm day, and periodically shut of the engine and look carefully to see when and where the first water appears.
        I may have the answer for you. I have the same boat, a 2010, and had the same problem. It turned out that the drain hose for one of the fish boxes was never attached. Oops. Anytime wieght shifts to port, the drain hole goes below the water line; and if that hose is not attached, water flows directly into the engine compartment. Fortunately, the connector for this hose is attached to the rear, port side of the rear fish box, and can be reached easily by lifting the engine cover. You might want to check the fish box closer to the front too. If I remember right, you can check the front hose via the treaded access cover under the passenger seat. Good luck. I hope this helps you out.
          the dealer found that the front hose was not connected,you are wright it is under the front seat through a inspection plate.but did not fix the problem
            tassjo, have you verified that all of the hoses between the cockpit and the thru-hull fittings are installed and the hoses themselves are leak free? Are both ends of those hoses attached and include a tightened screw clamp? Are all of the thru-hull fittings tight to the hull and caulked leak free? The bilge plug is tight? Some folks reported slight leaking thru the winch hook bolt.
            Saving the worst for last, the gasket which seals the transom around the drive could be leaking. The engine in my Donzi had to be pulled to replace my gasket.
            Good luck and be sure to post the final resolution.
            John C
              checked the 2 hoses on the port side(thats the 1 the dealer fixed,both have clamps on both sides)also checked hoses for the self drainning deck(all ok)will probley block them of, just with a tapperderd rubber bung as i go offshore a lot.i think it could be the seal for the leg(out drive)as u mentioned.i am not very impressed, that was the reason why i wanted a new boat so i dont have probs like this
                dealer rang today they said the water was comming from the ski hooks (but i dont think so) will pick boat up & test it on the weekend
                  You would think with the obama economy killing boat sales (and just about everything else) that Bayliner would at least attempt to sell quality products.. The problems I encountered with my '08 were easily recified by me. Good luck.
                  John C
                    went out on saturday no water in hull.water comming from ski hooks they also removed the brass fitting for the bung & resealed it .happy chap,thanks for the advise
