Transom mounted TRIM switch-gctid352652
    Any ideas where I might get a Transom mounted TRIM rocker switch to suit a 205 ?
    Post 397 in the giant small bow rider thread.
      I picked this one up on ebay for $45. Haven't had a chance to put it in yet as boat is in storage till April.Here a some picks of the trim switch.
      [img]/media/kunena/attachments/vb/656047=24838-trim_2.jpg[/img]
      [img]/media/kunena/attachments/vb/656047=24839-trim_1.jpg[/img]I don't know if this is the correct one with round plugs, if not I'll cut them off and wire directly to the existing switch.Skygazer is this the same one you have?
        I assume the transom mount plus into this bit at the back ?
        Attached files [img]/media/kunena/attachments/vb/656101=24853-photo 1.JPG[/img] [img]/media/kunena/attachments/vb/656101=24854-photo 2.JPG[/img]
          I have this one and still need to install it. The engine will be out of the boat soon to replace the coupler and will make it easier to install this and connect it to the pump.
          Part # 87-815200A02
            That's my guess where it goes. I haven't had a chance to take a look as boat is in storage.
              nvrstsfd1 wrote:
              I picked this one up on http://"http://www.ebay.com/itm/2807...e: <br /> ebay for $45. Haven't had a chance to put it in yet as boat is in storage till April.Here a some picks of the trim switch.
              http://baylinerownersclub.org/media/....jpg&#91;/img]
              http://baylinerownersclub.org/media/....jpg&#91;/img]I don't know if this is the correct one with round plugs, if not I'll cut them off and wire directly to the existing switch.Skygazer is this the same one you have?
              Nope, that's not it. I'm out of town right now I'm so it's a bit hard for me to give a good response if you look into the old small bowrider thread the part numbers there and there were also pictures on not sure if they're still showing on there. When I get home this weekend I can get you the info if you still need it
                That's the switch I put on my boat. (post #1990 in the bowrider thread)I liked the flush mount, and white color. It's for the Alpha 1 gen 2 trim pump.Really looks nice installed.
                  This is the one I have installed on my last 2 boats. Surface mount, rubberized, 1 hole for the cable and 2 screw holes, done.http://www.ebay.com/itm/Weatherproof...item1e69876c88
                  [img]/media/kunena/attachments/vb/657582=24953-tiltntrim_6.jpg[/img]
                  [img]/media/kunena/attachments/vb/657582=24964-Trim.jpg[/img]
                  " WET EVER "
                  mmsi 338108404
                  mmsi 338124956
                    That looks fantastic! How does it attach to the trim pump?
                      I put mine on the starboard side, near the boarding ladder.
                        I make all the connections directly at the trim pump solenoids.Switch common to red (battery positive) , blue / white, and looks like orange / white ? (bad pic)
                        " WET EVER "
                        mmsi 338108404
                        mmsi 338124956
                          Well, the local boat shop originally delivered the A02, but it has the wrong fitting, so returned it for the A01 which has the round plugs.
                          I will fit it this weekend.
                          I love it that the box is labelled "made in Mexico July 1991" and I am putting it into a 2004 boat.
                            I have attached pics of mine. It is Mercury Part #87-815200A02
                            This is the one mod we use ALL the time
                            Attached files [img]/media/kunena/attachments/vb/657991=24979-100_5026.jpg[/img] [img]/media/kunena/attachments/vb/657991=24978-87-815200A02_med.jpg[/img]
                              Hey Peggy, that is the same location I will put it on mine.
                              I will also try and mount the wired remote control unit for the Fusion stereo there as well.
