sterndrive hydrofoil
    I recently purchased a 2002 Capri 185 3.0 and the added hyrdrofoil is bent. Is it OK to just take it off and leave the holes open on the sterndrive?
    The hydrofoil will make a big difference- Have you considered removing the foil and straightening the bend? I think it would be okay to run with the holes exposed but if you plan to not go back to the foil I would fill the holes. The foil does not look bent in your photo. Maybe older photo?
    Gibraltar, Mi.
    1986- 3870- Hino 175's
    1988 26' Shamrock/ Diesel
    14' Zodiac Bay Runner
    • C-ya
      C-ya commented
      Sunbird, it looks to me like it is bent on the corner closest to the camera.
    • glenh2nd
      glenh2nd commented
      C-ya is correct. Also it's aluminum and not easy to straighten. I'll give it a go without the hydrofoil and if I don't like it then I'll buy a new one. Thank you for the reply.
    Ok to test run it with the foil removed. As stated above if you decide to remove it permanently I’d fill the holes. Some guys like the foils and some guys don’t.
    "THE FIX"
    '93 2556
    Misc. projects thread
    • glenh2nd
      glenh2nd commented
      I've been reading they cause stress on the stern drive bearings. I guess I could just put the bolts back in, LOL.
    • builderdude
      builderdude commented
      Not sure there’d be any more stress than is already present. 😉
    You will be OK if you get some touch up paint and paint the inside of each hole to prevent the exposed raw metal from corroding.
    If in salt water, it is much more important to check for any blistering several times a year and touch it up as needed.
    Since those edges have already supported lifting force by the fin, we know the structure is fine.
    Due to the orientation and location of the holes, there will be no real impact on slicing though the water with open holes.
      I ended up ordering a Sport Marine SE Sport SE400 Hydro Foil that will also cover the old bolt holes. Thank you for all your replies.
      Next project, propeller!
        I went from a 21P to a 19P prop (both 3 blade) and I was pleased with the better holeshot and stability while skiing and tubing.....this was on my 1998 3.0
        3 blade 19P props are cheap and easy to find......I got mine from a prop shop that had a bunch of reconditioned ones.
        I just knew that I had to watch the tach to avoid over revving the engine if I was trying to cross the lake quickly.
        Since I was never a "go fast all the time" kind of person, so it was never a problem.
