Portlight Window VR6
    The portlight window in the VR6 head/changing room surely opens. I can't seem to be able to open mine. Can someone who has a VR6 explain how the window opens before I break something. Does it open from the top or bottom? Thanks.
    2017 Bayliner VR6
    Mercury Verado L4 200hp
    Hi, The window hinges from the top. Mine was also stuck but I gently prised it open from the bottom until it released from the seals around the frame. Be careful as the window is only plastic.
      Thanks markemax.
      2017 Bayliner VR6
        Window opened actually easy once I knew what I was doing. Thanks, again markemax.
        2017 Bayliner VR6
