2010 5.0 taping sound
    I have a 2010 f19 with a 5.0. I have a taping sound coming from the engine when running. At an idle the noise isnt there. It's not a rod knocking. Didnt do it last year. It had a tune up and an oil change before getting on the water this year. There is no performance problem, just a loud tick or tapping noise. It has a carburetor. Any thoughts?
    thanks for any help
    A tapping noise could be too much play in the valve train while ticking could be an exhaust leak.
      Can you record the sound or make a video and provide a way for us to listen/view?
      Do it at idle, then gently bring the speed up to 1200 rpm, then 1800 rpm and then back to idle.
      20-45 seconds would be nice to hear.
      Also move the Microphone to 3 locations...……..port side, stbd side, front of engine.
        Ok so I lost both sides exhaust manifold gaskets. The front on the port side and the back on the starboard side. Yay what fun. Can I run it like that or do I need to wait and get it fixed?
          From a safety standpoint there are two issues...……….
          Exhaust fumes possibly making it's way to where people congregate/sit
          Exhaust spark/heat igniting gaseous fumes in the engine compartment
          The leak will only get bigger over time.
            Fix it now; hot exhaust gases and potential to damage exhaust valve from backpressure sucking in air which will raise exhaust temps.
              And exhaust gas or more so the heat from it can burn anything that's in close proximity to it. Rubber hoses, wires etc.
              "THE FIX"
              Misc. projects thread
                and to an untrained ear, the failing exhaust gaskets could have been the "tapping" sound you were hearing when under power.... and the gaskets dont take long or much effort to replace UNLESS a stud should twist off when you are removing them...
                NU LIBERTE'
                Salem, OR
                5.7 OMC Cobra - 15.5x11 prop
                N2K equipped throughout..
                  When you decide to change them...I would hit all the bolts with PB Blaster solvent the day before and let it sit.
                  if a stud breaks off in head its fixable just added work to get it out. I just changed bolts on my truck because 2 bolts busted off and had to drill and use ease out...not fun and precise task to perform.
                  Mine sounded like a valve tapping but was exhaust leak.
                  You can also heat bolts up one at a time before removing which helps..make sure no gas fumes lingering.
                  2008 H210SS Four Winns
                  Volvo Penta 5.7 GISX
                  Prior: 1997 2050SS Bayliner
                  Brad / Texas Gulf Coast
