Warning Horn! Help!!
    I have a 2011 235 with a 350 mag mercruiser. I have a warning horn that beeps once every minute. No loss of power, fluids are good, voltage is good, engine temp is good. Any help is greatly appreciated.
    I’m betting you have a loose or shorting wire to a sensor. Which one is going to be a process of elimination. The gauge and alarm switch are separate, so I’m going to have make some guesses as to location. The oil pressure alarm is going to be just above the normal filter location port side aft. There will be two switches there. One for the alarm, one for the fuel pump safety switch. The water temperature alarm switch should be on or near the thermostat housing. Trouble is the other one is the sending unit for the gauge. I don’t know which is which. That ought to get you started.
    • Shawn235
      Shawn235 commented
      Thanks I’ll see what I can find.
    A mercruiser engine scanner will allow you to read out fault codes.
      Could it be your carbon monoxide sensor beeping?
      2009 Discovery 192
      3.0 L w/TKS, Alpha 1
      Vancouver, Canada
        Mercruiser warning horns.pdf
          I also agree that if your boat is equipped with one, it could be this, CO sensors have a certain life span, and when the go bad they start beeping to let you know they need to be replaced.
