Bottom Paint
    Bottom Paint
    What’s everyone using for bottom Paint ?
    I use Interlux ULTRA in Alaska salt water.
      Pettit Hydrocote Eco. Two year intervals, very little prep necessary, North Puget Sound.
      Tally and Vicki
      "Wickus" Meridian 341
      MMSI 338014939
        Sea Hawk Smart Solution on my previous boat. Moored in brackish water. Previous boat cruised at 25kn and copper is not legal on pleasure craft in Washington....but I understand that's under review. Something about the alternative paints being worse than copper.
          Copper is not banned in Washington - that decision was postponed (not sure for how long). I put Seahawk Cukote (copper) on my moored Meridian just over a year ago and it has had very little growth... holding up great.
          1995 Bayliner 2452 Mercruiser 5.7L Alpha 1 Gen 2
            My dealer screwed up my bottom. Only a few months in the water when the boat was pulled for the winter there was a ton of barnacles and growth. So I basically have to reprep the bottom and paint it. So any advice would be great
              So you narrowed it down for us, David. You boat is in salt water.
              Tally and Vicki
              MMSI 338014939
                Did your dealer use " hard or Ablative " bottom paint.?? Keep,in mind ablative can go over hard paint, hard paint NOT over ablative. You might talk to local boat yard to get an idea of what they use,what works well in one area might not work so good in another.....Hope this helps...Brad
                Brad & Sharon
                Lady Jake
                LaConner,Wa. (summer)
                kailua Kona,Hi (Winter)
                  They used a no sand primer and and ablative paint a couple of hours before the boat was launched
                    Had the same issue a few years back -- I think it was my own fault for not mixing the paint enough. This time I used a mixer attached to a cordless drill and got it super well mixed.
                    I just redid mine and used Pettit Horizon -- I could have gone a 3rd season.
                    Terry
                    1999 Bayliner 3388
                    Twin Cummins 4BTA
                    Fisherman, Cruiser, Boaticus-enthusiasticus-maximus
                    Member Royal Victoria Yacht Club
                      I also have to paint a new water line cause the dealer painted too low. So I will have to prep the new surface also. I sanded s lot of the barnacles off and got it too the fiberglass. How do you know if you sanded too much fiberglass off?
