Ocean Use.....
    Ocean Use.....
    It seems the majority of owners on this forum are lake boaters but I was curious if there were any ocean boaters? I plan to trailer my boat but use it in Cape Cod MA. Mainly coves and bays but will venture out into the sound on calm days. Curious if there are any other ocean dwellers out there??!!
    HMMM
    I actually thoght that the forum is very well balanced.
    Most larger boats are used on oceans, and most smaller boats are designed for and used on inland waters.
    • Gboater
      Gboater commented
      Thanks Kevin
    I due coastal boating off the south shore of long Island. depending on the winds I can handle 2 to 3' seas if necessary but avoid 3 to 4' seas
    Ron
    1989 3218
    1988 Boston Whaler 13 Super Sport Limited
    2007 Yamaha VX Cruiser
    • Gboater
      Gboater commented
      Thx Ron. What size boat do you have?
    I have the 3218, which is actually about 34 feet
    Ron
    1989 3218
      Exclusively ocean and bay use.
      Larry Purcell
      1999 2452 Classic
      Merc 5.0L, Alpha 1 Gen 2
      San Diego, CA
      • wufibugs
        wufibugs commented
        Larry, I too am in San Diego and am repowering a 1986 2450, Is your boat salt or fresh water cooled?
        When I got it the 5.0 was a large solid piece of rust. My grandson and I marinized a 5.7 [350] fuel injected vortec out of a Suburban. I also got hold of a 280 duo prop to replace the 270 outdrive.
        My boating experience is sailing so I have tons of questions, Glad I found the forum
      I’m all coastal use in the Mediterranean... Bayliner 185, not great in anything over a 2’ wave but we do get flat sheltered water most weeks and I stick within 5 miles of shore.
      • Gboater
        Gboater commented
        Thx bennyboy. Jealous of your location in the Mediterranean! Nice to know you can still take her 5 miles out in the ocean on a calm day.
      GBoater, what of rig do you have? I have a 1997 Capri 1952 and am fine around Buzzards Bay unless its real bad out or tons of boat traffic.
        have one of each....one fresh water for lakes and rivers.....and one in a slip soaking in salt......and a lonely/grumpy wife constantly reminding of both
          My 38 lives in the ocean.
          Jim Gandee
          1989 3888
          Hino 175's
          Fire Escape
          Fyrflyer@ca.rr.com
            I am in both waters, the lake when restricted to home, to AK for great fishing 50+ radius of Ketchikan AK, as you can see 28Feet long I run from run from Prince Rupert N. to get there just watch the weather at the Dixson entrants about 25 mile crossing with the remaining run fairly protected.
              I Moore on Lake Washington but do a lot of cruising on the Salish Sea via the Ballard (Hiram M Chittenden) Locks.San Juan's, Gulf Islands and South Puget Sound.
              Ted G
              The Great PNW
              86 2850 Contessa SB
              Designers Edition
              Mercury 350 Mag
              290 Volvo DP
                While technically we are on the ocean, the Puget Sound is much more tame than the Great Lakes. We are very protected in general. Rarely, but notably, our waters show us that respect is due. If you have taken your vessel offshore, I'd consider that Ocean use. There are lots of salt water cruising areas that are a lot safer than some of the larger fresh water sites.
                Tally and Vicki
                "Wickus" Meridian 341
                MMSI 338014939
                  The OP mentions Cape Cod which is made up of many areas... Cape Cod Bay & Buzzards Bay primarily, but the outer cape is nothing but the Atlantic. I've spent most of my time in Buzzards Bay, Cape Cod Bay and Vineyard Sound. While not a massive area (28 miles long, 8 miles wide), i've been in 5-6+ foot breakers in Buzzards Bay when it is a beautiful day out (this in a 27 foot Sea Ray Amberjack). I'd be comfortable in my Bayliner in much smaller seas, which do present themselves at times in Buzzards Bay & the fishing is out of this world. Cape Cod Bay can get hairy if you go a few miles off shore without a doubt.
                    Its not the size of the boat, but the knowledge of the skipper, that determines the success.
                    I knew a guy who would take his home made wood skiff out to Cortez Bank, off of southern California, from Long Beach.
                    I have made this run in a 65 footer before, and it can get hairy.
                    He was a diver, and photographed some outstanding underwater photography.....
                    He would wear his wet suit, while running, because of the spray he caught under way.
                      I have used my bowrider in Long Island Sound but only on calm days and with the bow cover on (and life jackets worn)! The Sound is often calm in the mornings in the summer but can turn rougher in the afternoon as the air heats up and winds pick up. Also its mostly shallow depth contributes to frequent rough seas there. There are a few very good fishing spots about half way across between New York and Connecticut (Eaton's Neck Triangle).
                      Long Island Sound Region
