i was getting gas today in my 07 bayliner 175 and a guy came over to check out my boat. said he has an 88 bayliner 2 something , cant remember model. showed me pics and its totally done over. anyway he said he had to get a new lower unit and it cost 4k dollars. is this true and how long does a lower unit usually last? thought that was crazy.
cost to replace lower unit?-gctid406221
The '88 has an OMC, not manufactured anymore. Still, $4G's sounds high, unless freshly rebuilt, and then still high. Kinda sounds like an insurance deal to me.
You have the Merc Alpha One Gen 2 . New lower replacement, figure about $1500 or so for a Merc. SEI (sterndrive engineering) makes an exact clone for Merc Alphas with a very good reputation. Figure about $800 for one of those.
As Tbear said, seems pretty steep for price! Here in Canada, I priced out lower units because I don't like the nic's and scrapes on mine, $1000 for refurbished or $2000 brand new, so similar to Tbear's prices. Perhaps there is more to the story and buddy paid that for a complete upper and lower unit?
The lower unit will last practically forever if you take care of it (check and change the drive lube annually).
The OMC's like to eat gears if the shift cable isn't adjusted correctly and replacement gearsets are really expensive. Finding someone who wants to and knows how to work on them isn't easy either.
are those prices for labor also? if so much better than 4 grand. also person i bought boat from said shift into gear fast.. is this correct? thanks for info. all
No dilly dally gear grinding or you will..........:sorrow:
" WET EVER "
mmsi 338108404
mmsi 338124956
