Dash refurb pics-gctid406090
    HI guys, I got my boat in april and love its looks, but i didnt like the look of that walnut dash!!! To me it just looked dated.Here are a few pics of dash, before and after. Im very please on how it turned out so i went ahead and covered the glovebox lid as well.
    [img]/media/kunena/attachments/vb/709836=30368-scotts iphone 423.jpg[/img]
    [img]/media/kunena/attachments/vb/709836=30370-scotts iphone 429.jpg[/img]
    [img]/media/kunena/attachments/vb/709836=30369-scotts iphone 437.jpg[/img]
    [img]/media/kunena/attachments/vb/709836=30371-scotts iphone 442.jpg[/img]
    [img]/media/kunena/attachments/vb/709836=30367-scotts iphone 445.jpg[/img]
    Heres a better pic, as you can see it matches my trim
    [img]/media/kunena/attachments/vb/709837=30372-scotts iphone 447.jpg[/img]
      Nice !
        Very nice!
        Care to run us through how you removed the gauges from the surround ect.. As I'd like to paint mine :-)
          [QUOTE]kidafa wrote:
          Very nice!
          Hey Kidafa,
          First i drew a picture on paper of the dash i so could remember the correct order they came out, The pic i drew was from the back (under the dash) so i could write down the order of the wiring. I was lucky in the fact the wiring was numbered on each terninal connector, so i just wrote the number in order on the paper in the in the picture of each gauge i drew. Dont forget to write down what each gauge or switch is for on the paper!!
          Once the wiring was off and tucked out the way i then removed the 2 nuts on each gauge so could remove the bracket holding them in. The gauges just pulled out, them laid out on the floor in order.
          The switches pushed out by squeezing the two taps on each end of the switch from the back.
          Ingtion switch was removed by un screwing and removing the plastic nut on the front.
          I then removed the screws holding in the surrond.....voila!! done!!
          I was going to paint mine also but then had a changed of hart, so i covered it to match the trim. I also used a thin layer of foam on the surround before covering it just to give it some depth and texture.
          Good luck with your mate
            looks great. What did you use as a backer to the foam and vinyle??
              Hi Mate, I just used contact glue as this was just the job for it. I didnt use any glue on the front of the surround just incase i wanted to remove it. By ruffing up the back of the surround the glue stuck well. heres a pic of the back of the surround
              http://baylinerownersclub.org/media/....jpg[/img]
