Hello folks -my first post here. Will be taking delivery of my new 160OB (60hp) bowrider next week. Purchased a Garmin 421s gps/ depthsounder, and intend on installing it myself. Can anyone give me an idea of where to attatch the power cable? Is there a convenient place to connect at the fusebox or does one need to purchase a harness adaptor? I would also like to add a 12v powerpoint. Any advice on where to make these connections would be appreciated!
2012 Bayliner 160OB adding electronics-gctid405063
On my 180 we simply tapped into power and ground available right behind the dash (there is no "fusebox" per se). I added a 12v adapter to the passenger side, and I tapped into the radio power and ground for that. The driver side already had a 12v outlet.
My depth guage is tapped off the fuse panel under the dash, just make sure you are using inline fuses when you tap the power .
I just bought a 2012 Bayliner 185, and while I didn't look that closely at the OB models, all the ones I did look at had an "accessory" switch on the dash. That's your 12Vdc right there for things like a fish finder.
Although you do not mention it be very careful in how and where you install any transom mounted sounding transducer. A poor installation can result in water intrusion into the transom. Also placement is important for optimum performance.
There are ways of mounting a transom transducer without drilling below the water line screw holes.
Jim McNeely
Twin 5.7s with Bravo2 drives
Brighton, Michigan USA
MMSI # 367393410
The OB's do not have an accessory switch. At least all the '12's I saw on my dealer lot.
JimMc wrote:
Although you do not meantion it be very careful in how and where you install any transom mounted sounding transducer. A poor installation can result in water intrusion into the transom. Also placement is important for optimum performance.
With the helpful info here, I foresee adding one should not be too difficult (although it will likely take twice the expected amount of time to install, as is usually the case!)
I have a 12 adapter on mine that was dealer installed, it looks like it would be a snap to DIY in the garage.
There should be a fuse panel behind your gauge cluster,tap into that using a inline fuse adapter. As far as mounting your transducer,think about it a LONG TIME. You can mount it in your bilge or externally. If you mount it externally keep it away from the engine as far as possiable and be generous with the 3M 4200 in the screw hoses and the screws themselves.
FISHIN00 wrote:
There should be a fuse panel behind your gauge cluster,tap into that using a inline fuse adapter. As far as mounting your transducer,think about it a LONG TIME. You can mount it in your bilge or externally. If you mount it externally keep it away from the engine as far as possiable and [FONT]arial black wrote:
be generous with the 3M 4200 in the screw hoses and the screws themselves[/FONT].
Here is what I did as a retrofit this spring.
https://"http://www.baylinerownerscl...t<br /> <br />In the future this would be the way I would install a transom transducer.
If you decide you just can't resist drilling below the water line holes be sure to use a penetrating epoxy to seal the wood within. Also do not drill any deeper than necessary. Holes drilled very low on the transom MIGHT not penetrate into the interior wood in the transom.
Jim McNeely
MMSI # 367393410
Aside from the small area immediately backing the outboard mounting plate, there is no wood in the transom of these boats. Fiberglass all the way through
JimMc wrote:
Or don't drill any below the waterline holes in the boat.
