spare tire-gctid404564
    cant find a spare tire and rim anywhere. any idea where to get one for karavan trl?
    It would help knowing where you're located.
      etrailer.com
      They have the D rated rims/tires that I run on my Karavan trailer, you can also get the c rated variety
      What size are you looking for?
        mine are st175/80d 13c
          Looks like they have you covered.
          http://www.etrailer.com/dept-pg-Tire...5%7C80~13.aspx
            yep, thanks all
              well, i found a spare tire at of all places, LOWES. its a CARLISLE tire which is a good one with a white steel rim. only $95.00. thought it was a pretty good deal.
                You found a D rated tire in that size at lowes? I'd double check the load rating on that tire you just bought.
                The C rated will be around 1,360-lb
                D rated will be around 1,610lbs
                  size is st175/80D., load is 1100lbs. is this wrong tire? tire says B rated. JUST LOOKED AND TIRE THAT CAME WITH TRAILER IS RATED C. I dfont even see a D in the trailer ownwers manusl in a 175
                    B is definitly wrong.
                    1100x2 = 2200
                    Your boat weighs:
                    1847 dry
                    170lbs of fuel
                    300-400lbs of trailer?
                    Plus anything else you carry in the boat
                    = 2300lbs minimum
                    C Rated gets you 2720lbs of capacity - maybe that is factory for a 175
                    Mine is a 195 classic that weighs 2091 dry and came with D rated tires from the factory
                      isnt the 80D a D rated tire?
                        Nope
                        st175/80D13c
                        ST = trailer tire
                        175 = 175mm section width
                        80 = 80% sidewall aspect ratio
                        D = Bias Ply
                        13 = rim diameter
                        C = load rating
                          looks like im going back to lowes and ill find the right one at the website you gave earlier. i was just in a hurry to get one because i didnt want to not have a spare. UPDEATE,, I ORDERED ITEM # am31233. from etrailer.com. hope its the right one. thanks again.
                            Hi Nutsy,
                            This is a good idear to have a spare!!!
                            Can i ask if you are going to mount the spare in the trailer? If so how do you plan to do this.
                            Has anyone else done this and how have they mounted there spares?
                              baylinerscot wrote:
                              Hi Nutsy,
                              Spare tire bracket from NorthernTool or Fleetfarm costs about $25 - mounts to the side rails on the trailer frame.
