looking at 91 capri 2050-gctid401903
    Got a 2052(cuddy version) with 4.3L merc with Alpha 1....does 45mph ish, cruises nicely at 30mph @6 US gall/hr
    The 4.3L is more than enough for the hull IMHO, so the 5.0 will certainly go!
    Tank size is 30 US galls.
    Check the floor for rot!
    The skeg can be repaired,without removing gears, had mine done about £150
    Regards
    Pete
    Guest started a topic looking at 91 capri 2050-gctid401903
    Hello all,
    I just joined this group today. I'm looking at 91 capri 2050 to buy. from what I can tell its a 91 capri 2050 with a 5.0 mercruiser with alpha 1 outdrive. I don't have much info about the boat. the engine and outdrive look pretty good except the prop has a few dings and lower skeg is about 60% ground down, some of the seat cushions, side panels, and carpet need to be replaced. the hull is in great shape. the boat must have be outside most of the time as the gel coat is a little faded. just wondering what this boat might be worth in this condition.
    also how fast does this boat go, and how many gallons does the fuel tank hold.
    I currently have a 89 capri 19 ft with a 125 force outboard that I have had since 97. its a nice boat but thinking about something a little newer and thought about getting I/O this time.
    Jon
