Hi all, i'm new to this site, Brian from Australia wishing everyone a Happy New Year ! As for my New Years celebrations............well, they were cut short due to my bilge pump working overtime which had me worried so i upped anchor and headed home. My boat is a gorgeous Bayliner 195 Cuddy, fresh from it's service to both boat and trailer. I had seven aboard (all adults) to watch Sydney's fireworks, found our spot then anchored. That's when the problem started, the bilge pump was working overtime constantly pumping out water. So much so that I headed back rather than risk the bilge pump stopping. It has me baffled, when i took it out previously there was no trouble. With seven in the boat there was a small amount of water on the floor at the transom end but it's only natural to get and inch in there (self draining holes) with the added weight. These two holes in the side (in the photos) have me baffled, obviously the cause i'd say. With the added weight in the boat at least one was under the waterline. At home i put the hose into both and within a minute water starts pouring out of the bilge drain bung, so they have to be the problem as the hull is in pristine condition. Can anyone in here tell me what these two holes are for ? And do you think that something has come loose for them to be the way they are ? Many thanks in advance.
Brian.
Brian.
