What size is drain plug in 2005 bayliner 175. Where can I buy new one?
    What size is drainplug in 2005 Bayliner 175 and where can I buy a new one? Thanks!
    The transom plug? 1/2" NPT. Boat store, Amazon, Walmart.
    Mocoondo
    2002 Bayliner 195 Capri
    MMSI: 338091755
      Thank you!
        Does anyone know if these are all the same? I am in need of one for a 1998 Bayliner Capri 1954cl and not sure what size. Thank you in advance
          Same
          Best thing to buy is one of these
          https://www.westmarine.com/buy/braid...YaAq1jEALw_wcB
          THey not only hold the plug when not in use, it is a floaty for your keys and is also a good wrench for tightening and loosening the plug
          Boatless at this time
            I’ve measured the plug and from everything I’m seeing it’s 3/4” I see the size mentioned here is 1/2” but I don’t want to order the wrong one. Any help here would be greatly appreciated
              a 1/2" NPT drain plug will measure 3/4".... because its a "pipe" plug, which pipe is measured at the inside diameter of the pipe itself where the liquid flows, regardless of the thread size necessary to connect all the fittings together...
              the OD of the threads on a 3/4" pipe plug will measure 1".... a 1/2" garboard drain is very common, where 3/4" is rare and would likely have been installed aftermarket....
              1/2" pipe plugs can be purchased at some automotive stores that have a boating section, any "real" sporting goods store, any home improvement store or hardware store.... I would stick with either bronze, stainless or brass... in that order
              NU LIBERTE'
              Salem, OR
              5.7 OMC Cobra - 15.5x11 prop
              N2K equipped throughout..
