We were out today in our BR175 and that alarm ... the same one that sounds when you turn the key to start the ignition ... started sounding. We were under 5 mph in the harbor waiting for a dock to open up. We couldn't find a problem, so I started toggling the switched on the dashboard. I don't know if it is a coincidence or not, but the alarm shut off after toggling the bilge pump switch on and off.
Does it have an alarm when it's activated? There was no water in the bilge but I suppose the switch could be going bad or something. Any other reasons for the alarm while underway with all systems appearing to be normal?
