I've been having issues finding the right prop for my setup or type of boating and part of the reason for my issue is I believe the OEM RPM gauge is off by 400-1,000 rpm. The large difference is because I think the offset is percentage meaning the higher RPM the greater the increase in offset. Here's what is going on that is my issue.
Info on engine itself says 650RPM at neutral idle (non adjustable) and 625 in gear at idle. (or the other way around but not super important for this right up). My RPM gauge however shows almost 1,000rpm at idle. Engine specs in manual list 4,400 - 4,800 WOT (recommended) and rev limiter at 4,950. I figure I would see for myself what the manual says will happen when rev limiter is reached.
I was able to reach +/- 6,000 RPM without reaching rev limiter BUT GPS confirmed speeds are indicating the speeds that this vessel is supposed to be doing and has been posted by many boat reviewers.
So I'm thinking that at idle my RPM may be off by 400 but at WOT my RPM gauge is off by +/- 1,000.
Anyways this bring me to the topic of this thread Mercury's VesselView Module After reading up on it and reading many posts/comments and watching videos I decided to pull the trigger on this item for its many benefits BUT also as a tool to once and for all figuring this RPM offset issue I think I have. Called my local Mercury dealer (5min from my home) and ordered it. 370$cnd I figured at that price it wasn't worth it for me to source it from the states due to shipping, duty fees and taxes.
I started this thread for VR5 owners and any other owners interested in Mercury's VVM. I will be picking it up this morning and will document the installation with pictures. I already inspected engine to see if I could locate the required connector and WOW Mercury made is easy to find on the 4.5L (200hp) engine that I got in my 2017 VR5. The large black/grey plastic engine cover just lifts up and off its rubber grommets and just left of the main breaker is the RED Terminator plug. From everything I read on installing this I think the hardest part will be to find a suitable place to mount or position the module itself.
Steps and Pics coming soon.
