I replaced the positive battery cable on my 1986 Capri 1650 with an Aq131a engine. There is a purple wire that I think I moved out of the way, and now I can't remember if it goes to the starter or not. When I connect my test light to it and ground it the light flashes on and off and the engine won't start. When I disconnect the ground the engine starts and when I connect the purple wire to the open contact on the solenoid the engine starts. Does this purple wire go to this place?
