While on the water after a day of being on the hook, before I restart I always open the engine compartment and do a visual check of things. Well I found a bolt laying in the bilge that wasn't there before. It looks like one of these bolts that I circles. I looked around for an "empty" hole with threads.....the only one I could find was in the power steering pulley center. No bolt was there, the inside is threaded and the bolt fit in. I lightly screwed it in and left in for the return home. Boat ran fine, engine sounded good. I ran the boat before leaving our spot and looked at the pulley....it didn't seem to wobble at all, I don't know if I would see that or not. The pics that I found on line, didn't show a bolt in that pulley center. As mentioned, I didn't tighten down the bolt yet as I want to be sure that is the location where it goes. I literally looked for "open holes" for about 20 minutes and that was the only one I could find, right in front of the engine on the power steering pulley and the bolt was laying in the bilge right below.
Any help is always appreciate
