My local dealer told me parts are not made for boat any longer. Should I just call Bayliner dealers and see If they might have stock-I need the long decal that goes down the side as well as gelcoat. Thanks
2000 capri 1850-where can I find hull decals and gelcoat?-gctid812047
Same here RobMick. Once I got the non eroded gelcoat sanded down even with the rest of it. I decided I wanted a cleaner, more sleek look so I'm leaving some striping as well as the long lower hull billboards off. I did want to retain the Sunbridge identity but the logos were so bad I couldn't leave them what with all the sanding, compounding and buffing and polishing going on around them. I found Island Boat Lettering on NY. They helped me with the stern name and design so I sent them a couple of pictures of the 2655 SUNBRIDGE logo and within a week or so they had rendered a replacement decal that most will never notice the subtle differences between it and the original. I will be adding a red/blue stripe though. I'm extending the white on down from about a third of the gray lower wide stripe to the bottom of the vertical hull sides then changing to blue where the hull turns under. Sleek lookin hull you've got there. Are you required to display the registration above the rub line?
Sold:
Mariner 150
Towing with:
Near High Rock Lake, N.C.
I don't believe it is required to display the "MC" number above the rub line, it was there when we bought the boat...I will probably leave it there as time goes on
Lake Hartwell, GA
2012 BR 185 - 3.0 TKS
1987 SeaRay 300 - Twin 454’s
1995 Yamaha Waverunner III GP
1996 SeaDoo GTX
1999 SeaDoo GTX
