Help Converting Lounge to Pedestal Seat Please-gctid809170
I hope it is just screwed. Problem is I don't see any screws yetI will be removing some of the carpet and also inside to see what's going on. I would love some more room behind me but also adding the new seat I can have some more height to see over the windshield.
I will get lot's of photos along the way and make sure I post them here
I keep looking at the ratty lounges in my 2252 Capri and wondering if there is a way to simply mount captains chairs on top of the boxes rather than removing them. As much of a pain those things are they do give valuable storage I need. Has anyone ever mounted captains chairs like this? I can't seem to find any pictures or mention of doing it this way. Any ideas or pics please do direct me to them as mine were starting to look cruddy a decade ago and they aren't getting prettier.
I thought about leaving the box as well but the reason why I am installing the seat is so I have more room to walk and such. We will be using the boat mostly for fishing.
On my 87 1750 it is glassed in. Not screwed.. But I got most of the box out now and just have to do some trimming and get ready for new base to mount.
On my 87 1750 it is glassed in. Not screwed.. But I got most of the box out now and just have to do some trimming and get ready for new base to mount.hmy: :sick:
I have a 88. I just did the deck in. Bad news, it's fiberglassed in. Good news, it's separate from the deck.
Here's what I did. I used a angle grinder, with a thin cutting disk. Cut as close to the deck as I could and then use a sanding disk to make it flush with the deck. You'll need to re carpet the deck. And cover everything in plastic, you'll get fiberglass dust everywhere.
