Trailer help ???-gctid805050
    Hi, everything I read conflicts . I have just swapped trailers for bayliner 185. Have now got an indespension dipper three trailer. Keep adjusting the bunks but struggling to get them both to sit flush. What takes the weight of the boat the bunks or the keel rollers ?
    Well all of it really but most importantly is the keel. For example when a boat it on the hard the keel is blocked up and the side Jack are just to keep it from falling over.
    However when hauling its important that the bunks sit under.the stringers and support them. As the boat sits for a time on the trailer bunks in the wrong place can force the bottom of the boat into a negative warp or hook situational can negatively effect the performance
    Therefore it should fit as even as possible on the trailer but if not not a killer but should be remedied.
    1989 Avanti 3450 Sunbridge
    twin 454's
    MV Mar-Y-Sol
    Twin chevy 350's inboard
    Ben- Jamin
    spokane Washington
