Took a 1990 capri 18 ft with a 3.0 mercruiser out this weekend to try out before buying. I work with the current owner and he just got it back from the shop to have everything checked out. Machanic said everything works fine but when I had it out, the oil pressure was staying at 20. At one point it went up to 40 but didn't stay there long. This this normal for the 3.0? As long as he has had it, it's never wanted to idle without dieing. Can I adjust the carb to idle higher to fix that problem?
idle problem and oil pressure-gctid803837
Welcome! Two things going there. What oil is in the engine. Others are going to scoff, but my experience is I get better continual pressure, especially when slowing to an idle after a long run, when I use the Mercruiser or Quicksilver brand 25w-40. At the same time you may be dealing with a sticky gauge or sending unit. Something else to check.
As to the idle, if it dies when shifting; 1) he's shifting too slow, snap that thing into and out of gear, there's a shift interruptor mounted to the engine that kills the engine for a microsecond to allow the shift dogs to engage or disengage. 2) the idle mix screws may need to be adjusted, but the mechanic that just pronounced everything's goo to go should have caught that.
My oil pressure gauge at sea trial was fine. When I brought boat home and ran it for first time, it bounced about as yours seems to be doing. Ultimately, I was an oil pressure sending unit that was bad. I guess a simple fix. The type of oil I doubt would have anything to with the pressure of the system unless a different weight oil is being used from the recommended type. By law, a manufacturer cannot make you use their oil...if it's the same weight, then the the boat's performance should be the same.
Lake Hartwell, GA
2012 BR 185 - 3.0 TKS
1987 SeaRay 300 - Twin 454’s
1995 Yamaha Waverunner III GP
1996 SeaDoo GTX
1999 SeaDoo GTX
RobMick, please note t was referring to my personal experience. In a previous set of engines I tried several brands, weights and blends to prevent the warning system from going off due to low pressure after a long run. When I tried the brand name stuff the oil cooed faster and I stopped having low pressure issues. In no case did I attempt to infer, or would I ever, that the use of manufacturers brand oil was required.
"THE FIX"
'93 2556
Misc. projects thread https://www.baylinerownersclub.org/f...56-gctid789773
In your example, I would think that tthat he same weight oil would not send a low or false pressure reading...
Lake Hartwell, GA
1996 SeaDoo GTX
1999 SeaDoo GTX
Should idle in the water on a warm engine around 600-650 the less the better.
Don't want to idle " good ".
Low compression in one or more cylinders ?
Idle circuit in the carb clogged up ?
Temp this engine is running at ?
Choke opening all the way ?
Moisture in the dist. cap.
Run this engine in pitch black condition Zero light capiche ?
See if there are sparks all over the place.
1990 Bayliner ... leaky fuel tank .... water in the fuel maybe ?
"rivahlife" post=809234 wrote:
Haven't had a chance to put it on the water since that first time but I did put the muffs on today. At idle in and out of gear it was idling at 300 rpm. Shouldn't it be higher out of the water? Note I did fill the tank up and added royal purple's additive and ran much better this time.
"THE FIX"
'93 2556
