so the last 2 times out my 175 has started something that has me bit concerned.
when I am up on plane and trimmed up a bit, I will be cruising along and out of nowhere a loud rattles starts, It seems to be coming from the engine compartment. I throttle and trim down and the sound goes away.
I was also able to get the noise to happen when on plan trim was all the way down and started turning side to side quickly, just hold the wheel at 12 O'clock and got 9 O'clock to 3 O'clock several times and it started, the noise stayed there until I throttled down and came off of plane.
also a couple of times I was up on plane and trimmed up and when lowered the trim rather than throttling down first the noise would started until I throttle down.
each time I noticed the tach when this happens it seems to be around 4300 rpms or so.
any ideas?
any ideas?
