transom leak 1983 Cobra w/85 horse outboard-gctid749283
    Help!!! I just found what appears to be several leaks around the transom. When I pour water in the area with the drain hole by where the engine is attached to the transom and look at the transom from the inside I can see water leaking into the bilge. I can see hairline cracks in the fiberglass from the top on the outside also where engine is attached. Anyone out there that can give some direction to go in? If you look close you can see the water dripping down the back of the transom.
    Just added pictures
      Complete transome replacement, only option.
      Good engine buy a good hull.
        Ok. thanks. I was afraid of that.
