I am looking at a 2004 bayliner capri it is in emacculant condition only has 50hrs on it and has been kept in dry storage. they are only asking 16,000 i was wondewring if i could get some imput on this deal and if anyone knows about this model.
2004 bayliner 210 capri-gctid389368
The 210 was my choice & I love it. Mine was a new 07 and as most took a while to get the bugs out. I had some flex in the hull that took a lot before BAYLINER stepped up to the plate and finally fixed it. Look under the hull for fine cracks hopefully you wont have any. as far as value go to www.nada.com and if you have not yet made the purchase consider a survey.
Good Luck.
I think the suggestion to have a survey done (a real one) is worth it as $16k isn't just change.
Naturally the PO had told me that all services were made but they all will say it.......
