Oil Drain Hose-gctid387158
    Ok, quick one...hope I ask this right
    Is the oil drain hose (the one you use to change the oil through the drain plug hole) connected to a rotating fitting on the motor or is it a "solid fitting"?
    Hope that makes sense...there was a discussion on this and I have no idea, lol.
    Nope, it is a fitting to the pan with a nylon washer and does not swivel. - at least on my 2005
      They are made both ways. If you are buying a new one make sure you get the 2 piece one where the fitting screws into the drain plug the the hose screws into the fitting.
        Does someone have a pic of one installed or who sells them? Interested in finding more info on these. Thanks.
          Mine rotates at the pan...I think that all of the Quicksilver branded ones do this.
          Happy boating!
          Boating Supplies
            Jim McNeely
            Twin 5.7s with Bravo2 drives
            Brighton, Michigan USA
            MMSI # 367393410
              Thanks to all, very much appreciated
                Here is one that rotates at the pan: http://www.amazon.com/gp/product/ima...sporting-goods
                Here is one that is one piece, you have to rotate the entire assembly to install it. Fine if you have your engine out of the boat or lifted up, but a pain to try to install with the engine in place: http://marineenginedepot.com/PartIma...wivel_1166.jpg
                  Be careful if purchasing online. I ordered two that would not fit through a standard drain hole.
                  I made one our of the fittings and pushlock hose. It works nicely. I also ordered this: http://www.quickoildrainvalve.com/ which I think will be a more reliable system. I don't have to rely on the hose holding some of the oil. I think there is a potential for leaking with my current method, although it is nice.
                  Greg
                    Thanks again, ours is good, no issues. This was an inquiry for a buddy.
