What size prop-gctid385645
    Well my prop has taken a beating from the previous owner and I feel like its time to get a new one. So I'm looking to get a stainless prop but not sure what size I need. It's a capri ls 1850 with a 3.0 mercruiser 4 cyl. We do a lot of tubing and skiing so would like something to keep top end and maybe more whole shot action. Anyone with ideas or thoughts on what you like about the one you chose please chime in
    We just added a 4 blade 14x19p from turning point props and smart tabs (highly recommended), it is aluminum but we are really happy with it. It planes in seconds and cruises with 800lbs on board at 35mph. I'm able to trim just over 1/4 the prop has tons of lift. I just ordered turning point's 3 blade 14.25x21p too to see if it has more lift over the stock 21p merc prop.
      A prop from Turning point props.
      The HUSTLER 14 1/4x 21 pitch.
        What are the advantages of a 4 blade
          Never used one, but it is my understanding that a 4 blade = better hole shot but lower top end.
