So I want to put blue led lights under the gunnel of my 2003 Bayliner 185. I want to wrap around from under the steering wheel through the engine compartment and all the way around to under the glove box. All of the led ropes I've seen look like a tape. I want a tube style string of LEDs. I want to power it off of the accessories switch on the dash. Where can I get a set-up like this?
Under gunnel led lighting.-gctid690051
Do a google search for "12v blue LED rope lights" and you'll get plenty of options. Just run lights and wire them to your switch. I would use zip ties to hold the rope lights in place because that way you won't have to drill screws everywhere for mounting brackets.
