I have the sport seating with the sundeck and on the starboard side you can remove the seat cushion as well as 2 small cushions from the sun pad to make a walk thru when boarding the vessel from the swim platform.
I really like this feature, however, I have one complaint and wondering if this would be a good idea or a bad idea:
I may need some pictures for this and forgive my lack of terminology as I don't even know what it would be called just know how to describe it.
where the seat cushion goes its held in place by a recess in the fiberglass and a handle on the under side of the cushion. that recess is always holding water and so when we clean it we have to make sure that we either use a towel or something to get as much water out of it then use paper towels to dry it.
I was curious if it wouldn't hurt to take a 1/4inch drill bit and drill a hole to allow the water to drain below vs pooling in that recess.
I can provide pictures when I get home tonight if need be.
any suggestions, for some reason that standing water there bothers me...LOL?
you won't hurt my feelings if you say "just deal with it not an issue"
maybe its something that I should wait to do til the warranty is up so it won't void anything?
