Sound proofing my engine bay.-gctid650636
    My boat has the 4.3l 190hp engine. Its loud when under way. I read here alot of boaters sound proofing thier engines bay with desecnt results. I decided to give it a shot. Here is the picture
    Scott
    Bayliner 185 2007 - sports seating
    4.3L mercruiser - 190hp - Alpha one outdrive
    I dont go looking for no trouble but somehow trouble always seems to find me.
    results? happy with it?
      Didn't try it on the water yet. I will report as soon as i test it.
      Scott
        Nice work Scot. I put sound insulation on our 3.0L sterndirve (2007 175) and very happy with the result. Hope yours works just as well.
        2007 Bayliner 175 3.0l Mercruiser
        Lake use for water sports
        Victoria, Australia
          i did this a couple of weeks ago and i am very happy with the sound reduction. makes a big difference
            What product are you guys using?
            2003 Bayliner 1952 cuddy
              Good job, has anyone tried the paint on sound proofing?
                I used this from a supplier in Australia:
                https://www.whitworths.com.au/main_i...200&search123=
                Cheers, Greg
                Victoria, Australia
                  got mine from defender marine . was a noise reduction kit
                  http://search.defender.com/?expression=301129&x=8&y=7
                    I just went to h--depot and bought their silver/plastic duct insulation rolls and glued it to the inside of the engine cowl Big difference
                      Scott, how did this end up working? Worth the effort? Did you do anything other than the top?
                      2007 Bayliner 185 Sport 3,0 Merc TKS Alpha 1 gen 2.
                        Just the top. It did reduce the noise sum but still loud. It was very simple to install so it is definetly worth it.
                        Scott
                          While trying to quite down the motor noise from my 2007 192 3.0, I noticed that the side storage areas were not capped or sealed from the motor bay, I stuffed in a life jacket in each side to reduce the noise by about 50%. I also added some self stick foam tape to seal p the holes behind the rear seats. Look around for other sources of the motor noise if the blanket doesn't do enough.
                          2004 Bayliner 285 350 MPI Bravo III
                          2007 Bayliner 192 Discovery 3.0 135HP (sold)
                          2000 Ciera 2455 sold
                          Redmond, Washington
                          The one on the Left (Wet) Coast
                            Im trying also to reduce noise in my 2452. Did this, and will glue the old ones to hatch doors. I used local soundproofing product, meluton
                            Bayliner 2452 Classic / BMW M57
                            https://www.facebook.com/ruodollarokotettu/?fref=ts
                              Hi Greg
                              I have the same boat as you.
                              Could you please tell me what you did. What part did you sound proof?
                              Regards, Stefan
                              2007 Bayliner 175
                              Mercruiser 3.0 TKS
                              Alpha One gen ll
