175 buffer/wax options-gctid642540
    Have a boat less than 10 years old that i keep trailered and it is good shape overall. It could use a buff and wax and reading through the options for a novice, and a small boat, I was gonna start simple. BoatingMag suggested the Meguiar's drill attachment (I had looked at $100-200 polishers from dewalt or porter cable initially). It looks like a decent option and has decent boat-use reviews given the price. Anyone used this and also which items I should use for compound and wax? It looks like this is what I'd need:
    #45 oxidation remover with the red cutting/waxing pads
    #49 polish with the yellow polishing pad (or #59 wax instead? Or the black finishing/waxing pads?)
    Any thoughts/comments/suggestions? Thanks!
    Well I used
    http://www.harborfreight.com/power-t...her-66615.html
    If you have one near you. Works great but a little louder than a Dewalt
    And
    http://www.amazon.com/3M-Marine-Clea.../dp/B003XPJBFO
    Available at Worst Marine and other auto stores
    Boatless at this time
      Not sure if you have Harbor Freight in your area. But I purchased my polisher from them for $35. Well worth as the drill types just don't work well at all. Not enough power. Here is one similar to the one I purchased.
      7" Variable Speed Polisher
      Alaskanmutt,
      You beat me to the post. Darn slow wifi
      Patrick and Patti
      4588 Pilothouse 1991
      12ft Endeavor RIB 2013
      M/V "Paloma"
      MMSI # 338142921
        http://www.baylinerownersclub.org/in...ff-2015#626096
        Doug ;}
        MMSI: 338068776
        sigpic
          I employ a nice young lady who uses a harbor freight buffer. $10 a foot, and worth every penny.
            Fast 4G
            LOL
              http://www.harborfreight.com/7-in-10...Speed Polisher
              Alaskanmutt,
              Not sure when you bought the cheaper harbor freight model but I recently bought the same one and it SUCKS! The older model worked great. They changed the variable speed option and the motor takes a while to get up to speed off the trigger. Guess that may be good for a newbie for not slinging compound everywhere but if you are used to a polisher it will drive you crazy. I am thinking about trying the digital one instead.... On the other hand, I burned my last harbor freight polisher out after 2 years so I may just go name brand on this tool...
              2012 185 4.3l
                I've been using one of these http://www.supercheapauto.com.au/onl...ecommendations
                Works really well and is very easy to use without any swirl marks.
                  I have the digital one. No trigger. Turn it on then set the speed, it does a slow start but only takes a second or two to get up to speed. Bought it like 2 years ago when I was visiting Doug in Florida (no Harbor Freight here)
                    I have one like that too, but for waxing only. It doesn't seem to cut the oxidation like a rotary polisher
                      I used Collinite Fleetwax 870 on my 2009 192. Took me about an hour without using a buffer.
                      2009 Discovery 192
                      3.0 L w/TKS, Alpha 1
                      Vancouver, Canada
                        If your gonna do it don't skimp on the pennies .....get a good tool and use the right gear...good luck and post a few pics when your done before and after.....Marty...
