175 Rear port-side seat - mold - poor drainage-gctid375313
    When we bought our boat, the rear port seat had pink mold stuff on the cushion. Looks like this area does not drain well at all. Anyone else have a problem with this?
    Do you mean on the top of the upholstery or underneath? I've noticed no problem on top, but underneath it can puddle a bit, since there is no storage cutout like on the starboard side. It doesn't seem to be a big issue though.
    Jim
      The whole thing was soaked pretty well and the pink stain was on the white vinyl. I was able to remove the stain though.
      Just a warning to people - make sure you keep it dry!
        Mine has small holes in each corner for drainage. I also remove the seat cushions during storage.
          My seats in the rear of my 175 have started getting water logged too, the water gets in through the stiched seams and can't get out easily. The port side is above the fule tank so there's no ventelation or hole in the fibergalss below it, the starboard side has storage below the seat and warm air from the engine so it dries out better.
          We have to take out both rear seats and dry them after using the boat so we need a better solution for this too
