Has anyone ever put a heater in there cuddy. with an i/o and on board fuel tank did not know about fumes never smell anything. i have a mr. heater, propane heater uses small green bottles.. thanks Craig
Cuddy Cabin heater-gctid373840
Those work fine, you shouldn't have any fumes if the propane is attached properly. If it's leaking, you'll smell it! Don't store propane below decks, only out in the open. That heater should also have a low-oxygen sensor that will shut it down.
Jeff & Tara (And Hobie too)Lake Havasu City, AZ
|Current: 2022 Sun Tracker Sport Fish 22 XP3 w/ Mercury 200
And 13 others...
Also install your own sensor in case the one on the unit doesn't work. It will warn you. Its not the fumes I would worry about, its the lack of oxygen. Also I would leave a vent open a bit.
Doug
Doug
