I love my 175, but two things I haven't been fond of are the extremely low height of the seats, and the lack of readily accessible storage space. This winter, I decided to attempt to improve both issues by making taller seat bases with useable storage space underneath.The basic construction is 3/4" furniture grade plywood, screwed and glued, painted on the inside, and carpeted on the outside similar to the factory plastic bases. I obtained the taupe carpeting from Overtons, colorwise it is an exact match to the deck carpet, although a thicker pile. I think newer 175's than mine have gray carpeting. Each base is screwed to the floor with a total of 6 sheet metal screws. The base is the same length as the factory base, but the height is 9" vs. 6" on the original. The width is a bit wider than the factory base, but still narrower than the seats themselves. In order to match the geometry of the interlocking hole pattern for the seat capture poles, I templated one of the factory bases on brown paper with the side of a crayon. The forward storage opening is equipped with bungee cord to hold a plastic bin & lid in place. Enough room for flares, horn, handheld VHS, wallet, keys, whatever. The admiral is bestowed exclusive rights to the identical bin under the shotgun seat. I plan to store my wakeboard bindings, tow ropees, and a first aid kit in one of the aft storage areas, and a low profile collapsible cooler available from Overtons in the other.The extra 3" of seat height puts my eyes above the windshield bar and well above the side window glass. A much better view all around, and your head is still below direct wind. The extra seat height relative to the throttle lever is also a more comfortable arrangement for me. Coincident with this change, I also installed the Teleflex tilt steering kit. Since the tilt steering helm moves the wheel aft, I installed the driver side seat base about 3" aft of the original factory location. This does crowd the legroom for the aft facing seat, but that was a tradeoff that I felt was worth it. If I adjust the driver seat to the maximum aft location, I can stand at the wheel for docking, and with the tilt steering I can now reach the wheel when doing so. I filled the old screw holes in the deck with clear silicone, and embedded some carpet fibers in the goop to hide them. The two forward fasteners on the factory bases are actually stainless bolts, threaded into metal sockets embedded in the deck plywood. A couple of those were very difficult to remove, as there was surface rust in the fitting (but not on the stainless bolts). Carbon steel sockets perhaps? To fill and preserve those holes/socket fittings, I installed new bolts, well greased, with fender washers.I also added pole clips to the outside of the starboard base, to store a telescoping boat hook, which you can see in one of the pictures. I re-used the existing aft storage endboards that extend along the rear edge of the seat base to the hull. They are just 3/8" plywood with glued carpet, attached with 1-5/8" screws from the inside. I did not re-install the forward end boards, as they didn't seem to serve much purpose, and that should allow me to stuff a thin bag or whatever in there if needed.The effort involved to fabricate these seat bases was significantly more than I anticipated, but I'm pleased with the results.
[img]/media/kunena/attachments/vb/675290=26559-IMG_2442_5x6.jpg[/img]
[img]/media/kunena/attachments/vb/675290=26561-IMG_2481_5x6.jpg[/img]
[img]/media/kunena/attachments/vb/675290=26560-IMG_2484_5x6.jpg[/img]
