I need to replace the ice chest on my 87 1700 Capri-gctid371294
  • I need to replace the ice chest on my 87 1700 Capri-gctid371294
    Has anyone modified the opening to accept a standard cooler or a storage box?
    The replacement was around $175 the last time I priced them and it isn't made very well. My lip has been cracked for 10+ years and it finally came off. I've always used it for storage.
    I can attach a photo if needed.
    [img]/media/kunena/attachments/vb/675469=26569-2012-04-17 13.00.25.jpg[/img]Here is the photo.
      I have the same problem. I duct taped the lip :thumb . But I'd like to replace it.
      Keep the thread updated if you find something.
        They occasionaly come up on ebay. got one two years ago for about $35 and I thought that was enough. Mine was missing when I bought the boat. Didn't know there was supposed to be one until I bought a Bayliner brochure and thumbing through it they showed the cooler tray(as I will call it) The only thing I don't know is if there is something that connects to it, like a drain tube or a on/off valve. If your's has something like that could you post a picture of it. Right now I only use it for storage as water would drain out as the ice would melt with nothing to plug it and I don't like to have water in the bottom.
        Was this available at a Bayliner dealer that it was $175.00?
          Yes, I priced it at a dealer a couple of years ago. What did you search for on ebay?
          It does have a short drain tube.
            SCHAAKDAD wrote:
            They occasionaly come up on ebay. got one two years ago for about $35 and I thought that was enough. Mine was missing when I bought the boat. Didn't know there was supposed to be one until I bought a Bayliner brochure and thumbing through it they showed the cooler tray(as I will call it) The only thing I don't know is if there is something that connects to it, like a drain tube or a on/off valve. If your's has something like that could you post a picture of it. Right now I only use it for storage as water would drain out as the ice would melt with nothing to plug it and I don't like to have water in the bottom.Was this available at a Bayliner dealer that it was $175.00?
            Mine has a tube, i'm assuming going to the bilge and pumped out with the pump.Here's some pics ...
            http://baylinerownersclub.org/media/...3733.JPG[/img]
            http://baylinerownersclub.org/media/...3734.JPG[/img]
              Please attach photos of the moterwell cover with it lying on a couple of yard sticks or tape measures. Kim Ritz will make me one, but she doesn't have a pattern,Thanks.
                My ebay search usually involves Bayliner Capri. You will sift through a lot of pages. I look occasionally go through them all as I am still in search of the round letter B applique/decal thingy that goes on the glass trim on both sides of the boat.
                  Thanks.
                    The end of the tube is supposed to be pointed toward the bilge pump.
                      I have a short crack in mine. I was thinking about doing a fiberglass repair to the plastic tub. Not sure if it would melt the plastic. I will have to try on a test spot first. If it works it would really help with the strength of the lip.
                        I may try welding it with a plastic welder.
                          Plastic welding might work if the plastic is thick enough. Mine also wasn't supported accross the back of the tub which is what caused some of my cracking. I am going to add a support to help solve the problem.
                          • #14
                            A Utility Hatch Liner is an option.
                            The 13x17 liner should fit.
