I have a Bayliner 170 OB with a Karavan trailer. This trailer has Sure-Lube system. Dealer didn't really explain the exact steps for inspecting the hubs, as we are told to do often. The Karavan book and web site don't go into detail either. What I need to know are the exact steps I should do, and how often, to ensure the hubs are properly lubed. Thanks.
Trailer hub inspection-gctid365708
i pump grease in mine once mid season (till you see some come out, best to be doing while spinning the tire if possible) and again in the winterization process. i dont know if that is to much or to little, but when i take everything apart every fall i have never seen water intrusion or anything bad in my hubs/bearings.
FWIW, i launch in salt water.
If this trailer is new to you, I'd take no one's word at what condition these are in.
I would suggest pulling each hub and inspecting the bearings........ Look for yourself, and begin your season knowing that all is A-OK.
For a small trailer, bearings/seals are very inexpensive, and very easy to install.
If in good condition, clean them, pack them, and button it back up.
Now.... If you truly have an EZ Lube type hub (not hubs with Bearing Buddies), you can expect a full exchange of grease when using this system.
Do as StitchSC said, and raise the wheels off of the ground and turn them while you pump the new grease in.
This runs the rollers against the inner/outer races changing positions while the grease is entering.
You will always want to spin the hub while adding new grease.
Rick E. Gresham, Oregon
