Can you move everything but the starter to the house battery? Looks like in the mercruiser 4cyl wiring diagram that wire #6 (red/purple) feeds everything and is attached to the starter solenoid off what looks to be some sort of fuse. I was thinking of just moving that #6 wire to the house battery which looks like it would put the fuse panel/gages and everything else on the house one. Also if that is the common way whats the best way to extend that to the battery compartment? Solder and crimp with heatshrip wrap or maybe a anderson type plug like a sb50 (http://www.andersonpower.com/products/multipole-sb.html)?
Attached files [img]/media/kunena/attachments/vb/664030=25400-3-16-2012 3-46-05 PM.jpg[/img]
