2015 Bayliner Element SE Review-gctid649120
    2015 Element SE 75hp Mercury,
    Bimini, Cooler, Infinity Bluetooth Radio - 2 speakers, Humminbird 197c DI, Snap Trailering Cover
    Review based on 450lbs of crew/gear
    Planes in 2.5sec at 3/4 throttle, trimmed in all the way. Reaches 35mph at full throttle (mostly calm water) - but tach would be helpful for monitoring RPMs (husband says needed). Plenty of room to add one on the dash. Rides beautifully even for trolling. Runs and idles quiet - a plus when operating that Bluetooth radio (love ability to use Pandora with radio). While on that topic, the Infinity is clear sound at all volumes - worth the cost we paid.
    In significant chop, 20mph is the limit before ride becomes uncomfortable, but in conditions she was designed for the ride is fun, smooth, and comfy! Love low windshield, open profile. Handled 2ft waves fine when at a reasonable speed.
    Remains flat in turns and steering is average in responsiveness. (It's not a Vhull sport boat). Boat remains steady when boarding and exiting. Traction finish on the floor and in front of windshield helpful.
    Cushions remain secure and are comfortable! Love conversation style seating in cockpit and sun pad in aft. Really like the minimalist use of accent color on SE cushions vs base model. Forward bow cushion is tricky (husband says difficult) to snap and makes accessing the anchor quite fiddle-y (husband says pain in the a**). Cushion lift-tabs are located on the front edge of cushion, opposed to the back edge on the 2014s we looked at - and this seems to minimize risk of fiberglass damage which occurred under two cushions of the 2014 while people at the dealership were taking them on and off in wrong direction, not realizing you have to fish the clips under the fiberglass lip before pushing cushion down. You do have to be aware of the clips when putting on and removing the cushions, but with a minimal amount of attention this type of damage should be a non-issue on the 2015. Helm wedge cushion will creep up depending on size of your bottom, hence bottom snap, but handy and comfortable, bringing Captain within a comfortable distance from the steering wheel. I also appreciate the upgraded steering wheel and switches on the SE.
    Bimini great quality and rides well zipped up with very little bounce, if any. The port side bow hook-ring that holds the Bimini strap when set up, pokes into boat cover when snapped. Speaking of the cover - love custom snap cover over the mooring cover. In rain, water will pool on cover in two places - over port side aft cockpit seat and port stern. Plenty of ways to solve. Cover goes on much easier if you begin in the center of stern and work toward bow. Two poles, each snaps into cover from underneath. While on options - cooler isn't much but convenient storage design. You could also swap out for a portable live well in this area.
    The 12 gallon fuel tank is removable; however don't plan on it as the weight of a full tank makes it unmanageable. Instead buy a good long funnel. Fuel-efficiency is great and should easily allow for a full day of boating.
    Grab handles in all the right places and sun seats off stern, one with ladder, add built-in safety - and enjoyment while anchored at sand bar. While I thought I preferred the rubber rub rail on the standard Element, as soon as I saw this upgraded stainless rub rail in action I realized that I really preferred it against the wood docks at our lakes. You may want to consider adding an additional cleat or two in the deal.
    Storage is ample under all seats. However long items such as an oar will only fit when carefully fished under helm seat. For quick access buy a retractable handle oar.
    Four adults can enjoy spacious layout in comfort, 2 will feel like it's perfect in every way - boat certified up to 6 (cozy) people, 850lbs passenger weight.
    75 hp motors for the Element have trim limiter kits installed by Bayliner. Ours wasn't working due to mis-installation. Programming instructions must be followed precisely. Without limiter, the motor will hit/damage stern fiberglass if trimmed up too far. Also, because motor cannot be trimmed up all the way, the tilt lock latch on motor is not usable. The tilt lock latch is not for trailering, but only for use during motor maintenance. Maintenance can still be performed without latch. Make sure your limiter is functioning, but for the life of your boat realize this is something you need to be aware of when trimming. The motor does tilt up plenty high enough for traveling and going in and out of the ramp without ever being in danger of hitting bottom. You can find the four-page installation instruction on the trim limiter kit which I posted elsewhere on this forum. If you are looking to support your motor during transit, I have found two options that fit this boat and motor. The first is the traditional transom saver; however the trailer's running lights will be in the way of mounting the transom saver bracket. The trailer company does have a modification kit so that you can mount this bracket, and the instructions for that are listed in the same thread as mentioned above. It is my understanding that transom savers transfer load and road shock to your motor which I don't feel is a good thing. M-y Wedge makes a great motor support for this motor called the Universal Wedge. You simply trim up your motor and pop it on the hydraulic piston rod and trim back down to snug it on. Great support and easy to store; also affordable.
    The trailer has a folding tongue. Loading the boat at the ramp is quite easy with the M haul design, provided you don't put the trailer too far in the water. Adding side bunks would be helpful on windy days. Adding bunk glides to the bottom bunks would make the boat slide off much easier, allowing the trailer to stay further out of the water.
    In all, package was $18,100 out the door tax and reg incl. This also included purchase and installation of the Infinity Bluetooth radio system and the Humminbird depth finder. Price may or may not reflect consideration for the significant problems we had at our dealership. It's hard to find a new boat that will hold this number of people at this price. I feel the shortcomings of this boat are far outweighed by its price, fun, and comfort features. Take care of your motor maintenance and boat, and you should have an affordable package to enjoy for a long time.
    Oh - and she's really pretty! Go green!
    Very nice review. I really like the green exterior but could never live with the all white interior with 2 kids. The sand cushions hide dirt well. I have added a tach but have yet to take it out again I have just touched 40 MPH according to GPS and really wan't to see how many RPM's I'm turning. Maybe I can try a different size prop from the 13.25x17p I currently have. Smart tabs made a huge improvement in choppy water, where I used to be limited to around 20 MPH in a chop I can now cruise at 30-35 mph. I love my Lowrance =)
      I'd be really interested in the RPMs full throttle - post that photo next time you're on the water
        Very nice and very informative review. I think you like your boat.
        Rick Grew
        1981 Carver 3007 Aft Cabin
        2004 Past Commodore
        www.wrycc.com
          If this is a brand new engine have you run it in yet? I dont think running it full throttle is good for a new engine until after the initial running in period. Maybe there is no run in period? Check your owners manual.
          David
          1999 Bayliner 1750 Capri. 3l Mercruiser Alpha
          2014 Yamaha VX Cruiser
            I'm not sure if that was directed at the OP myself or both of us. The break in period is 10 hours and does allow full throttle in short bursts. But either way I have close to 50 hours.
              It was a question for the op. No horse in ths race, just a reminder to check if there is a run in period for his engine. I know my Waverunner had certain requirements (hrs) before opening her up to full throttle when it was new.
              David
                It's a very simple break in, first 2 hours vary the throttle and short burst to full for up to 1 minute every 10 minutes then next 8 hours no more than 5 minutes wide open at a time.
                  This was with 2 smaller adults and 2 kids in a moderate chop and fishing gear. At WOT we got to 5000 RPM's we were doing 37.5 MPH according to GPS. I have done slightly over 40 MPH on glass in 40* temperatures with just myself and son. It was 85* today. According to my math the day we hit 40 we should have been turning about 5400 RPM.
                  [attachment]14777 wrote:
                  WOT.jpg[/attachment]
                    Well I see the break-in instructions are provided already, but yes, this was under those parameters and always good to note the break-in for your motor - thanks Davidlyne. Now I will have to read up on recommended RPMs and considering installing a tach. Enjoy summer everyone; I am eager to share these memories with family and friends.
                      Mercury recommends 4500-5500 WOT RPM, preferably in the upper half of that. Trimming up the motor is good for a couple extra hundred RPM and MPH.
                        I was told these engines have a rev limiter design in. I believe the computer controls the RMP... This is the same engine block as the 90/115.... I think 2.1 Liter .
                        1987 3270MY, 135 Hino engines
                        2015 Element ( Lime Green) Limited Edition 75 HP Mercury.
                        Roger, Lake Saint Clair, Michigan
                        Fair Winds & Following Seas
                          Yes that is correct... Mercury 2.1 4stroke 75/90/110.
                          75 WOT is 5500, rev limiter kicking in 6200...
                          92 2855
                          91 Fourwinns 205
                            Did you install the Tach or have dealer install? How is it wired into the motor? This boat should have it as standard equipt and forget the speedo. Most GPS, even on my iphone, can tell me my speed. :whistle: ... Jeff
                            2016 Element 16' Merc 75 Hp OB
                            2003 Four Winns 190 220hp Volvo Penta I/O
                            1988 Sea Ray 21 Sorrento 200 Merc I/O
                            1980 Proline 17 Center Console Johnson 90 OB
                              I installed it myself. I ran a wire to the main engine harness where it plugs in to the motor and tapped in to the tach lead (grey wire I think).
                              Tom
