Trophy Pro 2103 Repower???
    I am curious if the added weight of approximately 100 lbs of a Suzuki DF225 up from a Mercury 225 EFI would cause any issues with handling/buoyancy.
    Thank you very much,
    Jason
    Welcome! Your question is the type that should be asked more often in my opinion. As a layperson, my first question to you would be is how much do the characteristics change when a person is located back next to the motor? It would probably be wise to add that 100 pounds into your loading calculation.....that I’m sure you calculate every time you go out. You could consider it to be similar to mounting a trolling motor. Again, part of the load calculation, but likely not a big factor after that. But that my uneducated opinion
