Starboard List, Water in Battery Compartment
    Hello All,
    I bought a 1984 Trophy 2460 about a month ago. Was finally able to drop her in the water this past weekend, first time since the sea trial. Mechanically, everything is great. Small issue with the 280 outdrive reverse lock but think I have that ironed out.
    A big concern is a pronounced starboard list. It sits about 3-4 inches lower than the port when at rest (pictured). So much so that the water line is about a 1/2 inch above the Sink drain thru-hull. On plane, the tabs correct it with no issue. As far as weight distribution, I there was no gear aboard aside from required safety gear. Heaviest piece being the anchor (~30 lbs) which was stowed in the center of the boat. Other than that, I (~190 lbs) was at the helm (SB side) and a friend (~240 lbs) port side passenger.
    After pulling her out of the water I opened the battery compartment (located SB side of the engine compartment) they were sitting in about 2-3 inches of water. I have no idea where that came in from, fairly calm water, no splashing over the rails. I checked checked every other accessible along the entire SB side of the hull, it was all dry. There doesnt seem to be any drain from the battery compartment into the bilge.
    Anyone have any insight on either issue?
    P.S. - Yes, the list is still present when free floating. The dock lines are slacked in the picture, they are not causing the list.
    Can not tell from your description, perhaps pictures of the compartment an surrounding area?
      Does the boat have a waste holding tank? And if so, is it on the SB side? If so, and it is 20 gallons (and full), that would be an additional 166 pounds of weight.
      1998 BL Ciera 2655 Sunbridge LX (Special Edition)
      "Sea Flights"
      5.7L 2bbl w/Thunderbolt Ignition and raw water cooling
      A​​​​​​lpha I Gen II Sterndrive/1.45:1 gears
      M15.25 X 15P Black Max prop
      MFG Extra's - A/C, Fresh Water Engine Flush port, HWH and Windlass
      Docks @ Punta Gorda, Florida
        If possible post some pics of all the compartments, port, starboard, fish wells, battery layout etc...
        What you describe sounds out of wack with the layout I would expect to see.
        Also the sink drain should be midship not near the stern.
        " WET EVER "
        mmsi 338108404
        mmsi 338124956
          Pics of the “battery compartment” may be helpful. Id suggest the batteries be moved over to the port side to help correct the listing issue.
          "THE FIX"
          Misc. projects thread
            The batteries are typically on the port side in this model, and they are not in any type on closed area, there is a path for water to flow through 2 stringers to the bildge.
            Sounds like there has been some "custom custom" stuff done to this barge.
            " WET EVER "
            mmsi 338108404
            mmsi 338124956
              Yep, never know what a PO may have done😳
              Im not familiar with his model but the “water in the battery compartment” didn’t sound right.
              Let’s hope for some detailed pics.
              "THE FIX"
                Originally posted by pgiconch View Post
                Does the boat have a waste holding tank? .
                No holding tank on this model, also the fresh water tank is located mid-ship center-line.
                " WET EVER "
                mmsi 338108404
                mmsi 338124956
                • pgiconch
                  pgiconch commented
                  Well that leaves that out. Appreciate the info.
                Here's a pic of a 1986 and the battery area is indeed on the starboard side, unlike my '89 model. I will assume the '84 is the same.
                " WET EVER "
                mmsi 338108404
                mmsi 338124956
                • builderdude
                  builderdude commented
                  Don’t see the pic😕
                I only see it with I sign in ??
                " WET EVER "
                mmsi 338108404
                mmsi 338124956
                  How about now ?
                  " WET EVER "
                  mmsi 338108404
                  mmsi 338124956
                  • builderdude
                    Yep, I see that one
                  My water heater leaked into the battery compartment
                  on my 2859. Several limber holes through the stringers
                  had clogged up. I used a hack saw blade to poke out
                  the clogs in all my limber holes.
                  1994 2859 in Tacoma, WA
                  7.4 Mercruiser
                  Still learning about other systems
                  and specs.
                    Sorry guys, been away from the computer for some time. Thanks for all of the responses.
                    I will take pictures of all the compartments this weekend and post them. As far as the layout, the picture above is pretty spot on. The battery hatch is on the left side of the engine (when facing aft as pictured).
                    There are no hatches nor any reasonable place to relocate the batteries to the port side. Then There is no holding tank.
                    The original port side companion seating (forward seat, double sided back rest, and pull out cushion to cover the bait well) was taken off and replaced with a large igloo cooler seat. Not real sure how much that original set up might've weighed?
                    Pickled the engine this past weekend. In for a long winter of head scratching and trying to figure out what is going on before spring.
                      What is under that hatch under the rear-facing seat?
                      in mine I have a rear facing seat aganst the forward bulkhead, a table that can be tsken apart and a forward facing seat above that hatch. The tacklebox is mounted under that seat. The table top fits between the seats and csn become a bed.
