1999 trophy 2002ff w/a
    I was trying to figure out what type of kicker bracket I can get for kicker 9.8 evenrude longshaft because the one I have now won't fully reach the water. Because I can't put the kicker bracket any lower because the back of my boat has raised lip on the transom I just wondering if anyone has same problem as I do with this
    thanks
    My 1993 model 2002WA has this kicker bracket. It was there when I bought the boat (used).
    No name, number or identification on the bracket. Powder coated aluminum. Maybe a custom fabrication. My kicker doesn't cavitate even if there is a wave that rolls up the port side pretty good.
ID:	502138Click image for larger version
ID:	502139Click image for larger version
ID:	502140Click image for larger version
      That's nice set up iam going to have look for something like that
      Is there any flex on transom
      thanks
        Nope, no flex on the transom.
          I have an adjustable kicker bracket on the back of my 1993 Trophy 2002WA. I like this set up because it lets me adjust the height for the motor depending on how deep the stern is. You loosen a knob next to the handle and simply push forward then re-tighten at the depth you want. This allows me to get the motor all the way out of the water so when I am running with the main motor it’s not dragging.
            Nice set up Yea I pretty much have the same thing but my problem is that the kicker is not far enough in the water with bracket fully extended
            and the back of my boat transom has like a ridge on it (as you can see it in the picture) so I can't put my bracket any lower because it won't set flush any I ideas
            thanks
              That bracket in the top posting was likely made by acompany in Surrey, B.C. I installed one 9 years ago and they are absolutely bullit proof. Yes, you will still need a long or xl shaft.
              Bob Hawes.
              Kelowna, B.C.
              1998 Trophy 2052 WA
              4.3 Vortec, A1 G2
                Ok I just found that bracket I do have the longshaft 9.9 . My boat is set up just a little different on the transom it has a lip on the transom and then just below that I have the self bailing deck holes
                I have pictures up there .
                thanks
                    Here picture of the the bracket extending out but its sitting at an angle because of the transom has a slight angle on it any idea would help
