2509 with water leak
    Hi, our new to us 1995 2509 has water coming in while running, I have replaced the front thru hull and that area is now dry when under way, checked the engine bolts, and plug. If we go out and run fast or slow for say 1 hour come back in and put boat up on lift the front is dry , back will appear to have very little water , come out next morning and will have close to 5 gallons in front bilge ? Any thoughts
    2001 4788
    Knott again
    Check the integrity of the caulking around the rub rail. Water can make its way into the hull between the upper and lower sandwiched pieces if the rub rail isn't sealed.
    1992 Bayliner Trophy 2502 WA
    2010 Twin Suzuki 140 HP OB's
    "Always finding improvement projects on this old lady..."
      If she’s gaining water while on the lift I’d also say the rub rail is a likely cause if it has rained during that time frame.
      "THE FIX"
      Misc. projects thread
