Grounding 1992 2002 WA
    I'm having trouble finding the "common ground" in the very tight/small hole accessing the battery wiring. Any thoughts, directions would help. Is this boat grounded at all?
    I'll take a stab at this. My '96 2002 FF with the '96 Mercury 175 hp has the large black cable that goes from the negative battery post to the block of the motor near the starter. That grounds the motor. What I found by the battery in behind the port side access door was several green wires that was the ground wires for the bilge pump, fuel sender, and the live well/fish well pumps. While never having the need to look for it. I assumed there is a ground wire in the motor harness that goes to the dash panel that provides a ground for the rest of the electrics at the helm. At the risk of being insulting, unlike automobiles, the entire boat is not grounded. Try Googling Bayliner Trophy Manuals. It's an old site that I believe is still accessible that has wiring diagrams for the older Trophys and was very helpful to me. Hope this helps.
      Dad, if those green wires are installed correctly, by ABYC rules they are bonding wires connecting everything metal to your anodes and the negative post on your battery. There should also be a black cable going to the motor and/or any other battery. It may be that a previous owner used green because it had better visibility than traditional black, or it was on sale. (Insert smile here) The new ABYC rules are to use yellow for dc systems under 50 volts. Sounds kind of strange, but when chasing a 12v ground you really don’t want to accidentally get 120v.
        No ground, it’ll be a 12 V negative
        92 it’ll be or should be a black wire.
        "THE FIX"
        Misc. projects thread
          Thanks for the responses , but I'm still confused. Are you saying the boat is not grounded?, or it is grounded to motor block? or? In a PERKO battery switch video on youtube they show black wires going to a "Common ground". I know some guys have a "block" bolted into their boat for all grounds. This 2002 WA has such limited access to under deck/wiring area I can't find stuff. Wiring diagram shows ground but where?
            What they are saying is "Ground" is the incorrect term. For a power source (Battery) you have supply (red) and return (black). Ground is a safety wire that connects back to return and generally does not carry any current and is only intended to do so if a short to a devices housing were to occur. It is also used in "Bonding" all the boats metal exposed to the water surrounding the boat to keep it at the some potential to minimize electrolysis.
              When boaters/fisherman state "make sure your boat is grounded" because of lightning, and in my case also electric current in the water from my down riggers scareing fish, what are they referring to?
                That would be a bonding ground that has an under water anode to dissipate charge from lighting into the water. This system only conducts current if hit by lighting.
                  Those green wires should be connected to any metal that goes through the hull, the engine and a zinc anode. Your electronics, and the 12v system could be connected to an external grounding plate bolted to the bottom of the boat. It’s easy to see if you have one, it will be a rectangular plate looking kind of like this.
                  https://www.google.com/search?client...dG_lXl8nWfzXM:
