Bayliner F series gunnel rod storage issue
    I noticed on my new to me Bayliner F16 on the gunnel Storage the black collar for where the rod tips go into the hole are all loose and can just pull out. I figured I would reseal but it seems that if the eye on the rod catches this Coker it will just pop it off again. What are others experiences with this?
    Congrats for your new boat. usually gunnel storage is useless for any boat less than 22-23 ft. so don't expect that it will be usable uless you have short stuff to hang.
      I have an F21 and none of my rods fit. I use it to store a paddle, telescoping boat hook and so on. The rod store inside the front left hatch is equally useless - due to hull curve the rubber clasps are pinching so tight that unless you are using straw thickness rods it's impossible to clip through. Still a good boat but those little things ...
