Thinking about hydraulic steering upgrade
    I have a 2002 2052WA with a 4.3 Merc and power assisted steering. I just got the boat late this past summer and when we were out I noticed there was a lot of " wondering" at low speeds. I have looked at both ends and all seems tight. When I grab the out drive there is very little play in it. After some research I am beginning to think that the cable might be stretched.
    So now the dilemma. Do I change the cable or do I upgrade to hydraulic steering.
    Has anyone changed the cable? Is it a hard job? Cost of the cable?
    Has any one installed hydraulic steering on a similar boat? How big of a job? Cost? What kit did you buy?
    (Just a little background I do 98% of the repaires to my vehicles so I consider myself fairly mechanically inclined. Also my son is an auto mechanic.)
    Any suggestions or advice is welcome.
    2002 Trophy Pro 2052WA 4.3L Mercruiser
    Ontario, Canada
    Most if not all sterndrive boats will wonder at low speeds, its just the way it is. Because of the prop being behind the boat it tends to want to if you will push the stern around past the bow.
    I do not think switching to hydraulic steering would help.
    Don
    1988 Bayliner 2455 (sold)
    1976 Tahiti 16.5 I/O (sold)
      Agree with Don on the low speed wonder, they all do it.
      New cable ($300-400) is the most inexpensive way to go if you even need one. Hydraulic convertion will likely cost 4x or more. Does she steer easily? Steering cables usually get replaced because of stiff or hard steering issues.
      "THE FIX"
      Misc. projects thread
        The wander something fierce even with counter rotation twins.
          I thought it was an abnormal thing as I found it was hard to control while idling out of the river to the lake. I also noticed that while turning the steering wheel It was almost a 1/4 to 1/3 of a turn from right to left before the "slack " was taken up.
          As for your question Dave I will say the force to steer the boat is normal.
          Ontario, Canada
            If you think you have that much slack in the steering, which, IMO, is too much, some simple diagnosis is needed. It's a matter of confirming what you think you are feeling. Iiwm, I'd start, with a helper, by holding on to the drive and trying to rotate it, then have your helper turn the wheel while you try to keep the drive from moving. If everything is tight, what you are experiencing is reaction time of the boat. If there's slack, go to the tiller connection. This is part of the power steering servo and steering cable connection. The tiller the bar that goes to the drive, the cable is obvious. Checking these is done with the helper turning the wheel while you observe, then by moving, or trying to, from the outside with one of you observing. If you haven't found the slack by then, check the connections of the steering mechanism to the "rack" that all is tight. If it is, unbolt the rack and have the helper try to turn the drive while you watch the gears. The last spot is the pinion. Use screwdriver to jam the gear against the housing and make sure that there is no slack there. By this time you should have located any slack in the system.
            if I missed something guys, speaking in a non gender way, chime in.
              I’ve found with low speed wonder making slight adjustments to the helm wheel and giving the boat a chance to react to those adjustments saves a guy from “over steering” trying to keep the boat headed in a perfectly strait line. In other words, Let it wonder some port to starboard.
              "THE FIX"
              • Nauti_Mike
                Nauti_Mike commented
                Agree, minor adjustment and wait for the boat to respond otherwise you'll be all over the place like a drunk sailor.
              Look this item up: https://www.ebay.com/itm/Sea-Star-HH...p/382677440944
                I will go through the testing and see how it fairs. I did something similar in late summer and if memory serves me correct it was loose where the cable meets the tiller bar on the stern of the boat.
                Drunken sailor. Exactly what i looked like. LOL
                Ontario, Canada
                  I added smart tabs to my 2002 FF 2001 and the boat stopped wandering almost completely
