F18 livewell issues
    F18 livewell issues
    anyone have any issues with the livewells? My back one works fine but cant get water to flow to the smaller front unit. Valve is open and hear feel pump working. Any ideerars
    When you run the front well do you shut the back valve ? If not I suggest you do that test first - that said my focus would be on the front valve. I would want to make sure that valve is working/opening properly. Consider removing the valve and just let water flow in - I haven't done this but assume you can remove the internal valve components. The second thing would be to look inside the console and confirm that you can see the pipes hooked up ... roughly where they should be. You can see the pipes and front live when you lean into the center console hatch door.
      Thanks will try
