Bayliner Element not Cranking
    I've got a 2018 Element E16. Mercury CT 60hp. About 60 hours on the motor. Took the boat out of storage and the motor won't turn over, even with a fully charged battery. I'm not hearing any noise at all when I turn the key. I replaced the key switch due to some corrosion, but that still didn't fix the issue. Any suggestions or anybody had similar issues? Help is appreciated!
    Check for voltage at the starter solenoid when turning the key to start position. Had the starter solenoid go on my 125 years ago. You can jump the solenoid to test it.
      this may be a stupid suggestion but are you sure you didn't remove the red battery shut off?
